How do you send a private message
ChadCallum1
Hi how do you send a private message to a a agent that has sent me a ticket that I need to reply to for the first time thanks you
2 REPLIES 2
@ChadCallum1
You can reply back to the agent on the envelope icon on your computer or your avatar then Messages on your phone and on the pen/paper icon.
@ChadCallum1
you can check your message here:
click on the message and you can reply it at the bottom of the message
or use this link to send a new message to CS_agent instead of reply
