Offer
Amysee
Public Mobile sent an offer of $28/mth.  I accidentally clicked yes.  It was a mistake and I need to cancel it.  I want to stay with my current plan of $25/mth.
Please help.
@Amysee wrote:
So I can click to cancel?  Before the next cycle begins?  My current plan will remain?
yes @Amysee  , you definitely can.  But wait 24 hours or you won't see the plan change there
or you can submit a ticket and ask PM support to help
Hey @Amysee
Yes, just click on cancel. It's that easy. Your current $25 plan will continue. Once again, it can take up to 72 hours to show up on your account as it did with mine when I switched over.
Amysee
hi @Amysee
wait 24 hours, login My Account, check Subscription & Add on page and you should see a plan change scheduled there.  You can then cancel it
or if you like, you can ask PM support agent to help to reverse it.
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
Chalupa_Batman
Please help.
Hello @Amysee
Just log into your account, go to Subscriptions and you will see this future change over. If it's not there, it may take a day or so to show up. Then cancel it. It's that easy.
