yesterday
- last edited
34m ago
Where are the terms or conditions of the offer located? How long do I have to except the offer?
So if I take it, do I get to first use the cdn wide data before using the cdn/usa/mex while in Canada?
35m ago - last edited 35m ago
Like other bonus offers, you will lose it if you change your plan.
As for the order of usage, from what I've observed, if you are in Canada, it will use this 5GB first, followed by the 10GB for 24 months (which was a bonus offered a couple of months ago), and then your regular data.
