Can not receive any text or phone calls
Ebbey
I already activated my phone but to confirm it I have to receive 6 digits Code from Public Mobile by text message the Public Mobile sent it but I can't receive it 😭 what I have to do. Is it possible for Public Mobile?to send it by email?
CSA_PM
Customer Support Agent
Hi
I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
hi @Ebbey
if you porting in  your number, the code would have sent to your old carrier sim, put it back and get the code
or if you still have trouble getting it, then ask PM support agent to help
you can submit  ticket by direct message:
Chalupa_Batman
Hello @Ebbey
If you can't get the text, click on "Didn't get code" and there should be an option for email. If the email option isn't there, then please create a ticket.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact them.
