09-10-2023
11:33 AM
09-12-2023
10:04 AM
Dunkman
09-10-2023 12:13 PM - edited 09-10-2023 12:14 PM
@Karenganda , to put an eSIM on your other phone you need to purchase another, Public Mobile doesn’t offer the option to transfer it from one phone to another 😞
For Existing Customers:
(I had my data on plus my Wi-Fi was turned on & connected to my home internet to be sure I had all connections while doing this)
I received an email notifying me that my SIM Card changed.
‘I can not stress this enough… please be patient when installing the eSIM’.
09-10-2023 11:53 AM
Thank for confirming that there is a fee.
I would suggest you get a SIM from your local Telus/Koodo store for $10 or order from Amazon for $4.99 so you can transfer between phones without hassle.
09-10-2023 11:44 AM
Hi @BKNS27 / @Karenganda
sorry, eSIM is only free for new activation. Reordering a new eSIM for another phone will be $5
09-10-2023 11:43 AM
eSIM is free so follow @softech recommendation and get a new eSIM by downloading the PM app on your new phone.
09-10-2023 11:43 AM
@Karenganda Yes unfortunately every time you need new eSIM even to change phones you need to re buy the eSIM
09-10-2023 11:40 AM
09-10-2023 11:40 AM
hello, but i already paid for the esim, if i delete my new public mobile esim and get a new one, do i need to pay again?
09-10-2023 11:39 AM
09-10-2023 11:38 AM
@Karenganda wrote:Hello i have e sim card, unfortunately i need to transfer it to my other phone. I mistakenly add it on my phone which has a sim already
you will then need to re-buy a new one
On your new phone, download the app, click ⊕ on the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now. You can buy and install eSIM from there
09-10-2023 11:37 AM
09-10-2023 11:36 AM
@Karenganda As long as that other phone is not already with PM then no problem . Just start the port request with other provider (other phone) and keep PM SIM card in the phone to reply YES to the confirmation text . And only use PM account number don’t use the IMEI as it’s not needed even if it asked for it
09-10-2023 11:35 AM
I have e sim card
09-10-2023 11:35 AM
it is easy, just remove the sim card from your old phone and insert it into the new one. If the size of the sim is too big, look careful, there should be removable "frame" to make it smaller
09-10-2023 11:35 AM
Do you have a physical sim card or an e-sim card? If the former, just take the sim out and put it in your new phone. If the latter you need to purchase a new esim via your self serve account because they can't yet be transfered between devices.
