How do I roam in South Kore
09-10-2023 10:18 AM
Hi! Community!!
I'd like to know how do I roam abroad for my phone number.
I am in South Korea and I will stay here for 2 month.
I need to get a roaming text. Please help me.
Thanks,
Add-Ons
09-10-2023 11:09 AM
if by chance you need to receive a text to your public mobile number for banking or other financial purposes, you’re out of luck if you have the public mobile SIM card with you out of the country.
If by any chance the SIM card is still in Canada, someone can pop it in their device and receive the code or other authentication you might need and provide you with those details to access services you may need.
09-10-2023 10:31 AM - edited 09-10-2023 10:31 AM
Sorry PM Roaming is not available in South Korea.
You will need to purchase a local SIM/eSIM there or use WhatsApp or TextNow app for free calling and texting through WiFi.
09-10-2023 10:20 AM
@Graceofjx Sorry PM only works in Canada and the US with US roaming . Best to bet local pre laid SIM card in Korea for your trip
09-10-2023 10:19 AM - edited 09-10-2023 10:22 AM
you'll need a local sim and cheap plan as PM has no options for roaming anywhere other than US. added..
if you'll have wifi, consider downloading free voip app like TextNow. You'll be able to make and receive free calls and texts to / from Canada and US using your wifi or separately purchased data.
