09-09-2023 06:54 PM
Does the U.S. Roaming 15 Day Talk and Text Add On include calls from the U.S. to Canada?
Add-Ons
09-10-2023 10:31 AM
Then you should have no problems. Leave networks on automatic and mode on LTE and roaming data on. That will give you the ability to use all services on both T-Mobile and AT&T as you go in and out of each others range/coverage.
09-10-2023 07:26 AM
Wow, great instructions! Thank you! Yes, it says registered under IMS.
09-09-2023 08:00 PM
No, go in to settings, about phone, status information, sim card status and look for any mention of IMS and that it says registered. For a further piece of proof, on that screen you see mobile voice network type. Make a call and see if that line changes to UMTS.
09-09-2023 07:14 PM
Thanks! That answers my question. And looking on my Samsung phone I see Network Mode starts with LTE so I believe that volte is enabled. Appreciate the help!
09-09-2023 07:07 PM
What type of phone do you have?
While you are roaming in the United States, you can make calls to anywhere in the United States and back to Canada. While roaming in the United States, you will receive calls from Canada and the United States. As if you were sitting in your living room. 🙂
09-09-2023 06:58 PM
No it hasn't been enabled yet, how do I check that?
09-09-2023 06:55 PM
Yes. Do you know if your phone has been enabled for volte here yet?
