Number transfer failed
Mizuki
Hi,
My number failed to transfer and I am unable to fill the form on the community to get this issue fixed. Can you please help @CS_Agent.
1 REPLY 1
@Mizuki
Transferring in?
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
If transfer outMake sure your PM account is active and you can still receive incoming calls and text
Then call your new provider and ask them to re-trigger the porting request.
Wait another hour or two and you should receive that
If still not receive the text from PM asking you to approve the porting,  please open ticket with PM support using this direct link:
