08-04-2024
09:50 PM
08-04-2024
09:54 PM
computergeek541
Hi, I record the message say transfer phone failure due to incorrect IMed. Could you please help? Is there a phone number I can call to resolve?
08-05-2024 01:25 PM - edited 08-05-2024 04:03 PM
no reason to repeat the same thing more than 15 hours later
08-04-2024 09:53 PM
@Heidihk23 wrote:Hi, I record the message say transfer phone failure due to incorrect IMed. Could you please help? Is there a phone number I can call to resolve?
Whenever possible, using the IMEI should be avoided and the old carrier's account number used instead.
08-04-2024 09:51 PM
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
