Number Transfer/port Text
murorange
Hi,
I received a text to enter '1' to authorize my number port. I texted '1'. A little bit later I received another one saying the same thing,  that they did not receive my authorization. It appears that the Public Mobile port system is not recognized my text. And, therefore, not completing the port.
murorange
Porting in to Public
The first message I received was at 2:18 and then received the same message again about an hour later.
Should I receive an acknowledgment text after texting '1'? Because I never received anything.
I switched my SIM to Public a few minutes ago and still no data yet.
I have already sent in a ticket this afternoon. Why do these things never go smoothly for me?!
Thank you,
Murray
murorange
Thank you,
Murray
hi @murorange how long have you waited after your Yes reply? Porting does not happen instantly after your text reply, it can take as longer as another 2 hours.  Try reboot your phone with the old sim and I'd you see the old sim stops working , then remove old and try the new sim
slusagm
If you are porting out,  ask your new provider to resend the porting request
And if you need PM to confirm,  just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
CSA_PM
Customer Support Agent
Hi there ...
Are you porting out? Or porting in?
