Notice of cancellation
Sarod2
I received a text message saying I am cancelling my account this is incorrect what do I do
Thats a *New One*! Nice to see something a little diffferent happening as long as it doesn’t turn out *BAD*. Keep us informed.
AE_Collector
Yes, @computergeek541 , that is a valid point.
Perhaps the OP in this case ought to submit a ticket to the Moderators to request why they received the message.
It does seem an unusual message to receive.
If I were to hazard another guess, perhaps the user is not the account holder, and maybe a parent/guardian is.   If so, perhaps they're doing something in self-serve that might have prompted the message to the phone user?   Can't imagine what, though...
@HALIMACS wrote:
Hi @Sarod2
Further to @NDesai information, I'll elaborate here if that helps.
In your self service account, choose Change Sim Card.
Ensure the last 4 digits on the self-serve SIM number match your SIM card to ensure you have not been sim jacked.
If they do not match, while still on the self-serve account, put your phone in lost/stolen mode and change the password. Then check and secure all your financials.
From, there, contact a moderator, there are 2 methods:
  1. Use the ticketing system - faster response time. Click on the bubble in the lower right corner and request moderator assistance, then select account-related issue, then select need a human now.  Follow the prompts to submit a ticket.
  2. Send a private message to the moderator through the following link  here
This doesn't sound to be the case to me.  I know someone using iMessage is possible, but if a SIM card was not still in use, there isn't any way to receive an SMS message.
HALIMACS
Hi @Sarod2
NDesai
@Sarod2 Which number did you get the text from? Login to your self-serve account and see if things look normal and you currently have services working. If not, match the sim number from your self-serve account with the one you have.
Gunner123
@Sarod2 sounds strange was it asking to port your number?
