Nothing is working!
TessaM
My credit card expired and I didn't get into the account to change it in time. Trying to do that now but I don't seem to have the correct email or password or pin for my phone number (which sounds ridiculous, but in our family we have multiple accounts tied to different email accounts - I thought I was using the correct one for my phone number, but my attempts to change the password have failed - no code gets sent to that email address when I ask for one). I tried to get a ticket so I could get help but I can't do that without a pin. I'm on the point of giving up - and just getting a new SIM card, losing my phone number and starting again. Any suggestions? This is so frustrating!
hairbag1
@TessaM
don't buy a new sim just yet.
You can go to 7/11 or Shell and buy payment vouchers to cover cost of your regular plan renewal...then dial 611 to add them and Reactivate that account.
DDM69
That would be frustrating. If it’s not too late, I would store all email addresses with login information somewhere to avoid future confusion.
@TessaM   you can open ticket again following steps below, it won't ask you for the PIN , or worst case, just use method 2 , message PM support directly
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
First type "Forgot log in Information", then click "Contact Us", then click "Click here to submit a ticket ↗
Next, enter your Community login, then select "Self-Serve Password Reset" and click "Next". and follow the steps
2. if you have problem with Chatbot: Private message CS Agent at:
