09-28-2023 04:26 PM
Since joining public mobile, first was the talk issue and now is my data not working, I’ve been a customer for 1 month and seriously considering switching to another network
09-28-2023 05:13 PM
@altautoinc data does not work anywhere with PM? or just at home?
First, make sure your update the iOS as well as the Carrier Profile
And click Reset Network Settings
Try changing the network mode, test each mode , 3G or 4G and 5G and see if any one works better
09-28-2023 04:49 PM
And the cell data permission?
09-28-2023 04:47 PM
Working fine on wifi!!
09-28-2023 04:46 PM
Is the browser you're using set to allow use of cell data? Does the browser you're using work on wifi?
09-28-2023 04:43 PM
no, i have an iPhone
09-28-2023 04:39 PM
I'm acquiring information from you to figure out what's wrong. If you were out of data then you would have received warning texts saying so. Do you have an Android with a data limiter set?
09-28-2023 04:37 PM
No not in usa i still have 36gb left, so why should i receive a low data warning????
09-28-2023 04:33 PM
Of course cell data is on? Do you have an Android with the data limiter set? Did you get any warning texts from here saying you're running low on data? Are you possibly in the states?
09-28-2023 04:30 PM
Yes it did at first, i have 40gb of data, and must of used 3gb, so i guess i still have data available
09-28-2023 04:28 PM
So you got the talk sorted?
For data, maybe you've run out of data depending on the plan you got last month. Did data work at first?
