Not recieving calls
06-01-2023 11:53 AM
06-09-2023 12:20 AM
Hi,
could I get this number as well. Thank you!
06-08-2023 09:43 PM - edited 06-08-2023 09:45 PM
did you just join PM and requested porting your number into PM ?
If you are porting your number, did you reply a text to your old provider and reply YES within 90 mins? If you miss that, the porting was not completed and hence you are not receiving incoming calls. There is a number you can call to talk to live support and re-trigger the process. I will message you the number, please check your Community inbox, envelope icon on top right
if you are not new to PM, incoming calls and text were working fine before and just not working now, try to :
- reboot your phone once.
- reseat your sim card (Power down the phone, take sim card out for a minute, then put it back and power up)
- change your Preferred Network Type or Network Mode on your phone to 3G Only (or WCDMA)
- Try to click Reset all networks and see if it helps (please note it will also delete your saved Wifi connections, but you can easily add them back later)
- if you have another phone, put your sim card in that other phone and test
- use your phone in another area, it could be a local network issue
06-08-2023 09:40 PM
Did you ever solve this problem. I have the same problem @mbella
06-01-2023 11:57 AM
I received it, thank you
06-01-2023 11:56 AM
watch the little envelop icon on top right side of this page will be highlighted when he sends your info.
06-01-2023 11:55 AM
@mbella Check you community in box already sent it to ya
06-01-2023 11:54 AM
Thank you.
06-01-2023 11:54 AM
are you a newer PM customer ? Have you successfully ported your old number in to your new PM account ?
06-01-2023 11:54 AM
@mbella Sounds like your port didn’t go through , I’ll send you number for live support to restart the port request
