Not receiving text messages
Deckerrg
I have an iPhone 8. I am able to receive text messages when I’m on wi fi but not able to when I am not on wi fi.
CountyDownIeUk
Firstly I say, leave your settings as is.
As mentioned , you are using iMessage ......blue bubbles.
Texting should still work “if” you send to a phone number and not an email address and “if” you receive on your phone number. So in your message settings......send/receive, only check your phone number...leave the registered email addresses unchecked.
Make sure your phone has most recent iOS update.
iphone  should switch  automatically but not always.
If you have limited data, then of course leave it off and do the occasional check for iMessages and turn data on, then of.
Both wife and I have iPhones, an 8+ and an XR and both of us had data off and no wifi connection and green bubble texting worked with no changes to settings.
Meow
Try not to use proprietary Apple's app. Use regular SMS app every phone has. iMessage uses WiFi or Data. Normal app uses only cellular service.
@Deckerrg
You are using iMessages.  That requires either Wifi and Data.  Either turn on your data or turn off iMessages and just use regular SMS texts.
hycm53
@Deckerrg Turn iPhone 8 Cellular data on at setting.
