10-27-2022 11:12 AM
I've been getting call backs and texts regarding my cellphone number. Apparently, someone is using my cellphone number to call and text people, and it's not me. Has anyone else had this issue?
Service
10-27-2022 11:30 AM
Most likely your number is spoofed by scammers and people called and seeing your number try to contact you and complain.
10-27-2022 11:28 AM
As mentioned spoofed numbers are easy to set up to annoy us all. I turn on DND 24/7 and reject any numbers that are not in my contacts. You still may get a voicemail and will show in recents. From their I decide to listen to voicemail or not or to block the number from recents. It works.
10-27-2022 11:14 AM
@MikerzJunior hi someone may be spoofing your number,not alot can be done about it but they usually move on in a few days
