Cell Service
se677ro
I have had no bars for telephone service in two days. i can not make calls or receive them. my account is active. i have reset my phone, i have toggled airplane.
Meow
It could be local cell tower has issues. Did you try to connect moving further from your current area (few km)?
se677ro
unfortunately no i do not
@se677ro   do you know anyone using Telus/Koodo/Bell/Virgin/Lucky might have experiencing problem in your area as well?
do you have another phone to test your sim card?  this can confirm if it is a device issue or network
se677ro
I can not text or use my data. and i have looked for outages in bowmanville to belleville area nothing still.
Dunkman
@se677ro
What about text and data?
Is there a report outage in your area?
https://www.telus.com/en/ab/outages
Other things to try:
Network reset of phone
Try your SIM card in another working phone. That helps determine whether hardware issue versus PM Service problem.
