05-27-2022 10:35 AM
I just registered with Public yesterday and I am able to make calls but not receiving incoming calls.
Can you explain possible reasons as to why? thanks
05-27-2022 07:31 PM
@fieraci wrote:I just registered with Public yesterday and I am able to make calls but not receiving incoming calls.
@fieraci - i guess that depends if you ported a phone number over or activated with a new number?
AND, if you ported over a number was it a mobile provider or a landline/voip provider phone number?
If you have activated a new account and transferred over from another provider, note that incoming calls are usually the last to port over.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If still issues, submit a ticket with Public Mobile representatives (CSA) for help; click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If you activated with a new number, try one or more of the below:
*turn off your phone completely for about a minute, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
05-27-2022 11:22 AM - edited 05-27-2022 11:22 AM
HI @fieraci Sound like it is a stuck poring problem if you have request porting in your old number
I will message you a number to call to live support, they can assist provide you update to your porting status and will advise what to do from there. Please check your inbox on the top right
05-27-2022 10:55 AM
Do you still have your old sim? You probably have a incomplete port. If so
Install old sim in phone, and reinitiate the port. You will be sent old sim confirming number port .
To reinitiate port contact CSA team via simon chatbot, or someone will likely message you the Telus porting number
05-27-2022 10:37 AM
- Did you follow all steps of activating new PM account?
- Did you port your old number (if any) to your new PM account?
Little bit more details of what you did is needed, if possible.
