Not receiving Incoming calls
Kennedy1105
Ever since switching to public mobile and using an eSIM I have not been able to receive incoming calls. Others are telling me my calls are going straight to voicemail.
2 REPLIES 2
Chalupa_Batman
Hey @Kennedy1105
How long ago did you port over to Public Mobile? It may be a porting problem if it was recent. However if you were getting calls after you signed up, you may need a network reset. Here's how to get a CS Agent to help you.
To contact a Customer Service Agent, please click on the following link.
Please be sure to keep an eye on the top right corner where you’ll see this icon show up.
HI @Kennedy1105
you ported in your phone number? if you requested port , then what you experiencing means the porting was not done.  The number still with your old carrier and the voicemail people got is your old carrier's VM
I will send you a number to PM porting them, they will re-initiate the porting request. Check your Community inbox and call them and get it fixed
(after PM re-initiate the request, you will need to put your old carrier sim card and wait for the text from your old carrier and reply Yes to complete the port)
