01-22-2024 09:55 AM - last edited on 01-22-2024 10:16 AM by computergeek541
01-22-2024 11:19 AM
5G availability dependent on service availability and type of phone (Samsung, Google, iPhone, etc.) 5G primarily a big city offering. Not available throughout Ontario.
01-22-2024 10:32 AM
I have only ever seen LTE or 4g while my wife's says 5g around the city. Phone is set to autoconnect to 5g
01-22-2024 10:29 AM
Have you tried to manually select 5G network?
Depending on specific location (ie, nearest cell tower), it is possible that LTE connection is the best one for your situation.
Here is some more info:
https://www.publicmobile.ca/en/ab/get-help/articles/speed-tiers
Might want to observe what happens when you travel around. You should get 5G connection in different locations.
Even customers on 3G and 4G plans can get 5G connection, but just have different capped data speeds.
01-22-2024 10:07 AM - edited 01-22-2024 11:44 AM
@Publskub yes unfortunately even with 4G plan is speeds up to 100mbs and 5G is up to 250mbs doesn’t mean you will always hit those numbers I have a Telus 5G+ plans that says speeds up to 2GBps but usually can only get 5-7 hundred mbs so just a 1/4 of the advertised speed . This is unfortunately normal for carriers . But at any given time those speeds test can be different due to network congestion location environment like construction and will give different results at different times
01-22-2024 10:03 AM
Have only seen speeds of 100mbs
01-22-2024 09:59 AM
@Publskub pM dose not give the 5G option to all 5G capable phones . Samsung s20 is prime example of this . But also note with phone set to LTE being in 5G plan its stilll possible to get speeds up to 250mbs
