11m ago
Can Public Mobile update customers device information. I keep getting text about my 3G device and It won't be compatible with the network starting March 2027. We'll, I don't have a 3G device.
3m ago
If you are getting notifications from PM regarding 2027.03 then you need new phone.
No matter how old or new your phone or from which company you bought or if it is VoLTE compatible - if it is NOT compatible with PM network – check VoLTE compatibility on PM site – then that phone will NOT work with PM services.
Your plan has nothing to do with phone compatibility; you can have the Most expensive plan but if phone is not compatible with PM then you will be charged extra or phone will not work at all.
ALWAYS check PM database with your phone’s IMEI – current phone or prospective purchase.
Check it here: https://www.publicmobile.ca/en/get-help/articles/volte - database is getting updated at on going basis so it might be inaccurate (but it is getting Better every day) and Best way is to contact agent for clarification (talking from personal experience) as they have access to the REAL compatibility database.
