Not data or phone working with my simm
aavenger
Totally dead I have an esimm with another provider but absolutely nothing working on my phone on
the public simm.
Timer
@aavenger
tried to reset network settings
and check  APN Settings
rebooting device. or insert your SIM card in other device.
Meow
Is your account Active?
When did you join PM?
Can you try your SIM in another phone?
@aavenger
Try rebooting your phone by powering the phone off if you just ported your number over from the other carrier.
SamanthaWaldrif
Have you tried resetting the phone?
Ensure that the sim card is inserted properly it could be put in upside down. (Happens more then you think)
HI @aavenger   did you just join?  was the sim card working before? or it never work since you joined?
you are using eSim with another provider, did you change the sim card assignment for proper slot for data, voice and text?  It usually under SIM card management and you need to pick the proper sim card slot for that
If the sim card works in such arrangement before, Check My Account and confirm your account is active
dust2dust
Can you try the sim in another phone? Is your account showing as active? Texts?
