Not connecting
Toronto1live
I topped up my phone and still cant call or receive text msgs also
1 REPLY 1
will13am
@Toronto1live , please check to make sure that your self serve account is active status.  If so you could try toggling the lost phone, found phone options in the account, followed by rebooting the phone.  If none of this works out, then I suggest contacting the moderators for assistance.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.  Good luck.
