Data not working
hawkinskayla
So I have a umdigi f2 and my data stopped working last month when I went over. Haven't had data since. They have reset the server. I have done a network reset did APN settings still nothing! Still have 8gs of data left. Please help
9 REPLIES 9
@hawkinskayla  Change the MVNO Type to GID and the APN name to sp.mb.com and save your settings.
Here are my APN settings on my F2.
Leave APN Type and MVNO value blank as they will automatically get set.
@hawkinskayla change your
APN: sp.mb.com
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
MVNO type: GID
MVNO value: 4D4F
Save. Enable data and try sending an mms message. Stay safe.
@hawkinskayla
Did you get hold of moderator before?  Is so, what did they say?
here is APN setting :
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
hawkinskayla
They already did that still no luck
hawkinskayla
Yes talk text work
hawkinskayla
geopublic
@hawkinskayla  Can you post a screenshot of your APN settings?
gblackma
@hawkinskayla  your SIM maynot have reset properly. Try the lost/ stolen trick to reset your service.  From your self service account enable the lost/ stolen feature log out, wait 5  minutes, log in and take it off. Log out and restart your phone. 20200504_182846.jpg
 If this fails contact the moderators and ask them to reset your service for you. There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
Dunkman
@hawkinskayla
Does your talk and text work?
Maybe try toggle airplane mode on, then off.
You can also try your SIM card in another working phone.  To help determine whether hardware issue versus PM service problem.
