05-04-2022
06:41 PM
05-05-2022
12:51 AM
computergeek541
My $25 plan says it includes receiving international text messages from overseas while I am in Canada. I am not able to receive any overseas text messages. Does anyone know how to make it work? Thanks!
05-04-2022 07:39 PM
@Kobebear wrote:My $25 plan says it includes receiving international text messages from overseas while I am in Canada. I am not able to receive any overseas text messages. Does anyone know how to make it work? Thanks!
@Kobebear - you should also be able to text overseas and internationally. Can you text to them? Unless this is a short code you are referring to.
If you just activated or porting a number over, these short codes could take a few days to 'find your phone' after a new activation.
05-04-2022 07:37 PM - edited 05-04-2022 07:37 PM
You can also download the WhatsApp for wifi international texting or calling but texting should come through PM.
05-04-2022 07:14 PM
I have had international texts come through no problem from the US, Caribbean countries and NZ, haven't had any from Europe so can't speak to that, but could just be the proper area code/number format
05-04-2022 06:55 PM
Perhaps the sender has restrictions preventing texts to foreign numbers, such as yours.
Also, check if you haven't blocked calls texts from sender.
05-04-2022 06:48 PM
@Kobebear All of the plans PM currently offers allow for unlimited incoming/outgoing global texting so you should definitely be able to send and receive.
You can try powering off phone, remove the SIM and after couple of mins. reinsert and reboot. Or try resetting your network settings.
If the incoming texts you're having an issue with are shortcodes from foreign banks, then you should know that PM doesn't support shortcodes from many of the overseas banks.
05-04-2022 06:46 PM
HI @Kobebear Yes it came with it. No special setup for us
It is your friends from overseas that need to check how he message you
Where is your friend from? how your friend entered the phone number to text you?
