Not able to receive 5G signal with 5G plan
BBQ_Pork_Buns
I have an S20 FE 5G and recently signed up for the BF $34/40GB 5G plan but I don't see 5G as an option in my network settings.
@hTideGnow wrote:
hi @BBQ_Pork_Buns it is a known issue that s20 series does not work on Telus 5G network
sure they do - they just don't work on the 5G network for public mobile customers
BBQ_Pork_Buns
@Handy1 wrote:
@BBQ_Pork_Buns  This is a s20 issue with PM you will still get better speeds with phone set to LTE then.being on  a 4G plan (100mbs) do speed test to confirm
Speed test
https://www.speedtest.net/apps
 just tested it and the speed is not good either
golfball
Your phone is likely not on the whitelist for 5G. I believe you need an iPhone or Galaxy S21 or newer, some other Android phones are supported as well.
But try 4G, it will give you as fast as 5G speed plan, like 200Mbps or more, for sure above the 100Mbps cap on 4G plan
Speed test
