04-29-2025
03:31 PM
04-29-2025
07:30 PM
computergeek541
For the past few days i have tried loging into my account on the app and website to change my subcription and have not been successful. It seems as if the website is broken? Any help is appreciated!
04-29-2025 04:16 PM - edited 04-29-2025 04:17 PM
Thanks @Techfish I meant to ask OP to uninstall and reinstall the app and try again and I missed that part
But one thing, PM support always able to help with login issue. Especially if OP tried on both website and app and fail, it most likely not a device issue then and engaging support for a resolution is needed
04-29-2025 04:11 PM - edited 04-29-2025 04:12 PM
The poster wrote that they tried both the app and website. Also, if it's a client device/browser issue (most likely is) then Public can't do much about it.
04-29-2025 04:10 PM
Are you seeing any specific error messages? Are you using Android or iOS?
I had a similar problem on my Samsung phone, I just temporarily changed the default browser to solve it. The Public app uses the default browser to load the log-in page.
04-29-2025 04:04 PM
@RoyDR did you try using Public Mobile app?
If that does not work still, message support for assistance. Private message CS Agent at:
04-29-2025 03:40 PM
@RoyDR try logging in using secret or private mode.
Clear browser cache.
Use another device or another web browser like Chroome or Firefox.
