Not a question, but it now appears the usage filters are working!!! :)
10-14-2022 04:19 PM
10-14-2022 06:14 PM
I would still more believe downloaded sheet than these filters.
10-14-2022 04:39 PM
@softechhmmm, I didn't do an exhaustive test just a couple using the custom date range for my plan date range. I did check the talk and data options and they seemed to be working fine. I'll have to check out the other options, I just normally am only interested in my usage for the current date range.
Cheers and thanks for the feedback!
10-14-2022 04:38 PM
10-14-2022 04:28 PM - edited 10-14-2022 04:45 PM
@Greg_R844 I don't think the filter is working 100%
If i go onto the site, without changing anything and just click filter 90 days , data, it does not work
But if I go onto the site, first thing i do is to filter 90 days for Talk, it works. Seems like after I filter 90 days for Talk, I can then filter 90 days for data and it works that way
So, it's still acting funny, work or not work. 😞
