Pin
10-14-2022 03:00 PM
Horrible business concept so far.
How can I receive my 4 digit pin to make a payment. I got a new phone recently..
Thank you.
Good luck to all
Payment
10-14-2022 06:18 PM
When opening an account you have been asked to create and REMEMBER your PIN.
I do not need luck with PM service; it works perfectly well for my needs and agents are very responsive wen needed. I guess they like my Community name 😘
10-14-2022 03:32 PM
How is PM responsible for the PIN you created when activating your SIM?
10-14-2022 03:02 PM - edited 10-14-2022 03:04 PM
@JmanPlumber hi you should have received one when you activated,go into your self serve account go to profile you can change/make a new one there
10-14-2022 03:02 PM - edited 10-14-2022 03:03 PM
Get payment voucher at Shell Gas or Walmart..then dial 611 to add them to your account. No PIN req'd.
10-14-2022 03:01 PM - edited 10-21-2022 03:39 AM
@JmanPlumber when you first activated your account, you would have set it up yourself
You can login to My Account to make a change to the 4 digits pin, and even make a payment.
To change 4 digits PIN, login to My Account, go to the profile page:
https://selfserve.publicmobile.ca/en/account/my-profile/edit/security-information
