06-04-2023 08:48 PM
I dont have an Android phone, is there a means to setup the plan without one?
It only indicated the requirement after I'd already paid.
06-04-2023 09:20 PM
Pinetime? Or Pinephone? Pinetime doesn't appear to be a cell watch. Pinephone seems very light on specific specs. Need more info.
06-04-2023 09:06 PM
Thank you, I will try for a refund before the sim ships. Cheers.
06-04-2023 09:05 PM - edited 06-04-2023 09:06 PM
All you need to do is to active your SIM then you can put it in any UNLOCKED or non-BLACKLISTED iPhone or Android phones.
To check if phone is Blacklisted/Lost/Stolen enter the IMEI of the phone:
06-04-2023 09:03 PM - edited 06-04-2023 09:03 PM
@sacked ,
Please send a CS_Agent a message & see what can be done. If you are told your device can not be used here I would think they would refund your money.
You can Click here to submit a ticket↗ through the virtual assistant. “This method uses the ticketing system for a faster response time”.
Alternatively, You can send a private message to a CS_Agent: -> https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 “This method takes longer to receive a response back”.
Customer Support Agents are available from:
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
06-04-2023 08:57 PM
06-04-2023 08:55 PM
I dont have an iPhone either. I'm using a Pinetime smartphone with no access to Google or Apple products.
06-04-2023 08:50 PM
@sacked Yea can use a apple iPhone instead
