@CS_Agent
HallowGreen
Need help with activating the E-Sim for my phone. The number successfully transferred, but the sim was not. How can this be fixed?
2 REPLIES 2
LitlLdy
@HallowGreen , please send a message to CS_Agent so it can be fixed for you.
You can  Click here to submit a ticket↗  through the virtual assistant. “This method uses the ticketing system for a faster response time”.
Alternatively, You can send a private message to a CS_Agent: ->   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437  “This method takes longer to receive a response back”.
Customer Support Agents are available from:
  • Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
@HallowGreen  First try rebooting the phone and or reset net work settings , if that doesn’t work contact support to fix
Message support directly
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
