No texting or phone
donaldsavoie
I can’t receive any phone calls and texts.  PLEASE HELP
10 REPLIES 10
donaldsavoie
Thank you so much!!
donaldsavoie
Been with PM for over one year.
@donaldsavoie wrote:
Yes I can phone, text and use data. I need to receive calls.
@donaldsavoie     Did you just port a number over to Public Mobile?
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Spoiler
Tried all your solutions except reset network setting.  How do I do that?
@donaldsavoie
Reset your Network Settings.
Tap Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
donaldsavoie
Yes
hairbag1
Where are you located in Canada ?
donaldsavoie
donaldsavoie
Spoiler
Hello @donaldsavoie
Are you a new customer, or an existing customer that had services prior to now?
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Are you able to MAKE calls and texts?
And does your data work?
@donaldsavoie  PM issue for the last couple days.
Try to put your network to 3G only.
Or put your SIM in a 2nd phone to test, it should work, then put it back to the original phone after.
many reported success with both methods above
