No signal
KOBISA
My phone gets disconnected from server and when someone calls me goes on answering machine
Please help
KOBISA
Hello,
Thank you for your email and concern. I have taken some troubleshooting steps: I rebooted my phone and also tried using my SIM card in a different phone for a few days before putting it back in my current phone. However, there is another issue now. My son informed me that sometimes when he tries to call me, he hears my phone ring but it doesn't go to voicemail, even though I haven't answered the call because my phone doesn't actually ring on my end. The only thing I haven't tried yet is resetting my network. Overall, the situation has improved, but there are still instances when callers hear my phone ring on their end but it doesn't actually ring on my side. It's quite strange. Thank you for your assistance and I hope we can resolve this issue soon.
RavingRaven
@softech
Probably but that doesn't explain why the issue came back a few days later unless my Sim card is on its way out and needs replacing?
@RavingRaven wrote:
@KOBISA
I've had a similar issue. I put my Sim card in my wife's phone and all was normal. While my Sim card was in my wife's phone I tried calling it from my fongo phone # and it rang. I put it back in mine and it was all working again.
@RavingRaven
by putting your sim in another phone, if forced a sim reprovision and hence resolved your problem
RavingRaven
@KOBISA
I didn't try a network reset because I didn't want to have to enter all the wifi passwords again. A couple of days later it happened again but fixed itself after about a half hour. Very strange.
KOBISA
Thanks a lot for your quick reply
I will try to use my sim card in my other phone and also I will restart all the network settings and let you know
Thanks again
@KOBISA
you rebooted your phone?
do you have another phone to test the sim card?
Also, try click Reset All Networks on your phone
