03-31-2020 12:39 PM - edited 01-05-2022 10:10 AM
03-31-2020 04:43 PM
Outage confirmed even on mobile syrup. If phone service is absolutely critical at all times, it is best to have overlapping service (e.g., home phone supplied by a different provider than cell phone).
https://mobilesyrup.com/2020/03/31/telus-service-outage-western-canada/
03-31-2020 12:49 PM
There is an outage for Telus networks in some areas.
You can check the outage map HERE
03-31-2020 12:41 PM
@EscobarA there is an outage affecting parts of Western Canada. In the meantime add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. Check to see if you are affected. https://www.telus.com/en/bc/outages . If not, please say so in order to get more help. Thanks.
Try restarting your phone. Turn it off, wait for 30 seconds and restart it.
03-31-2020 12:40 PM
@EscobarA wrote:No data service . Keeps coming in and out. We're going on?
Telus networks experiencing high than normal call volumes. Affecting the west mostly...but ok now in BC interior.
03-31-2020 12:39 PM
Telus outage. Look at the map for outages and status.
