No service
tehowennathe
All of a sudden my phone lost service. I checked and my account is active. I turned of phone and restarted I and nothing. I took out some card and that didn't do anything. I tried everything and nothing is working. I don't know what to do.
26 REPLIES 26
tehowennathe
It's all solved now. What caused it was an update sent by Blu. A factory reset fixed every. I should get an adapter.
@tehowennathe  I sometimes have to switch Sims between phone and saved the other sizes to use when needed. I've asked at some retailers if they have any extras on hand from another activation and they've been happy to supply them as they usually get tossed out. Alternatively a SIM adapter can be bought at places like best buy for $5 or on the internet for as low as $1.
@tehowennathe wrote:
@yanzhiqiang wrote:
Remove sim card, try it in a different phone, if working, then buy another phone. if not contact PM.
No one I know has a phone with same sim size so can't check. Would a factory reset work?
For future reference, the PM 3 in 1 SIMs can be "re-assembled" if you've saved the unused frames.
tehowennathe
It's set to 2G/3G/4G
I think it's your device. Even if there's an account issue or even you service is cancelled, you would still see networks when you scan.
Latest update from Blu caused sim to not work. Had to factory reset to get it working
Bold move, but in this case, warranted.
tehowennathe
A factory reset was needed. The update that Blu sent caused the issue. It's all fixed now
tehowennathe
Everyone I know has a different sim size. May have to factory reset since it happened after a few days later after a major update from Blu getting me out of pie beta
GinYVR
@tehowennatheI would suggest put your SIM card into another phone and see if the problem persists. That's the quickest way to figure out the root of your issue.
If you tried network reset and it didn't work, and you don't have alot to lose on your phone, a factory restore might work. Especially if the recent changes to your os caused it and you just found the trouble on your next restart?? I wouldn't rush to it though.
dabr
I know you said the account is active, but maybe try topping up your account with one dollar and then rebooting the phone.
tehowennathe
yanzhiqiang
tehowennathe
All I did was restart phone and then sim stopped
tehowennathe
Nothing is working. Says emergency calls only. When I try to manually search for network it says no networks found
None? That's strange. It could be a broken phone. Check if phone is set to 2g by mistake; Public won't work with it set to that.
tehowennathe
@hairbag1 wrote:
Long shot but...try putting the sim in the second sim slot.
It's already in second slot as my previous phone used micro SIM so it's on the micro SD slot
I am using a Blu Vivo XI+ which got out of beta for Pie on Monday. That's when I did an update to get out of beta. It was working well up until half an hour ago
Did you buy it new or used?  Did you check the national blacklist database?
tehowennathe
Plug phone into AC power supply for a start.
Is anything working ?...talk / text or data ?
tehowennathe
ChuckYeah
@tehowennathe  Did you try network reset? Check APN settings to see if they changed?
tsparkle21
Try toggling airplane mode on and off.
hairbag1
ChuckYeah
In order to better help you, we need more info about your issue:
What type of phone are you using?
What version of the OS?
Did anything happen of note? OS upgrade?
