06-26-2024 05:55 PM
Suddenly my phone won't work. I get this message. '' NOT REGISTERED ON NETWORK ''. I checked my account and all payments are up to date, everything is good... But no
06-26-2024 08:11 PM
What can we do if we do not have access to another phone? Is there any other way to fix this issue? Although it seems like there many others struggling with the same issue.
06-26-2024 06:59 PM
06-26-2024 06:58 PM
Thanks, reseting the networks worked!
06-26-2024 06:39 PM
having the same issue. I think there's a network issue right now.
06-26-2024 06:34 PM
is this a cellphone that you recently purchased using Craigslist or Kiji or some such ? It could be that phone has been reported stolen or blacklisted.
06-26-2024 06:25 PM
Hey @Coolhandloo_099
If you have a different cell phone lying around or someone close by who has one, shut down your phone and theirs, swap SIM cards. Then restart both phones. That in my experience has fixed the issue. If that does work, then swap SIM cards back.
06-26-2024 06:02 PM
@Coolhandloo_099 unfortunately, this happens sometimes 😕. Should fix itself.
Try any ar all below.
Restart, turn airplane mode on and off, turn data on and off. If all fail, reset networks.
Good luck.
