No service
Saaradil
Hello
I just loose service for my two line since almost one hour...
I'm in Montréal Québec .
Both line are active and everything is ok
No network any help plzzz
Reset phone tried everything's I suspect that the problem come from provider ..
@Saaradil
Other members also have reported outages in the Montreal area.
Here is the outage map to check:
https://istheservicedowncanada.com/status/telus/map
GeorgieBee
Same for both my husband and I.  We are on the Mtl south shore.
HALIMACS
@Saaradil
if you haven’t yet, try rebooting your device and removing and reinserting your Sim card (if it’s a physical Sim card and not eSIM)
Sometimes those simple tasks get reconnection to network when there is a temporary issue.
Saaradil
Sent message to CS agent and waiting ...thanks
Phil_Adelphus
I checked the Telus outage map too and didn't see Montreal having a problem but the website Downdetector shows people reporting problems with Telus in a few places including Montreal.
https://downdetector.ca/status/telus/
HI @Saaradil
maybe just outage in your area. I checked Telus outage page, nothing show for Montreal
Move around , maybe you will get network back
and chance your network type to try 3G, 4G and 5G
if you want, submit ticket with CS agent:
