No service in my home.
Mangaworm
Hi,
I have no luck reaching an agent this morning.
i have no service signal at my place, can’t receive a message & call. I would like to cancel the order from today.
can you help me with this?
thank you.
Sansan
It seems like there is a system wide outage  based on posts since yesterday from different locations.  Canceling your account is your choice however,  once everything is sorted out you should be fine so maybe you want to wait a few days?
Once your service is back online you can sign into your account to disable the auto pay. After 90 days of non payment and no funds to cover the balance, the account will be closed.
Or you can port the number out to a new provider.  But if you are doing that the account cannot be closed.
If you have already submitted a ticket, you just have to wait for their reply.
hairbag1
@Mangaworm
there was a significant wind event through BC and Alberta late yesterday evening...could be the cause of your issue (if you're in BC or N Alberta)
@Mangaworm  You can use this direct link to support
send  a  private message   To CS_Agents
hairbag1
@Mangaworm
use this link to message Customer Support...watch the little envelop icon on top right side will be highlighted when they respond....https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
added...forgot to add the link 🤔
