03-24-2023 12:28 PM
03-24-2023 12:33 PM
Indeed, the paste did not ‘take’ from the CSA contact.
03-24-2023 12:31 PM
HI @Coryp
you can submit ticket with PM agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-24-2023 12:31 PM
Expecting an edit from HALIMACS 🙂 Click on the chatbot (simon) link below and start a chat and then fiddle around until you get to submit a ticket.
03-24-2023 12:29 PM - edited 03-24-2023 12:30 PM
I am human, but I am not a public mobile employee. Is there something we might be able to help you with on this forum. If not, here’s how you contact the customer support agent.
Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your avatar
