03-24-2023 12:31 PM
It has been days that I have no internet connection even when my data is on and still have a lot of data remaining. My phone is Galaxy A31
03-24-2023 12:43 PM
@jrocampo Try this first to verify accurate up to date account info
simply try refreshing the page when logged in
03-24-2023 12:40 PM - edited 03-24-2023 12:41 PM
Refresh your browser page by clicking on the circular arrow to update your account to show current amount of data you have left.
03-24-2023 12:33 PM
HI @jrocampo
Maybe you are reading cached old usage info
Please login My Account using Incognito/Private/Secret browser mode again
If it shows you still have data, try to reboot your phone, and reset all networks on your phone (this will also reset your wifi saved connections, but you just need to reset them after)
if still not helping, please submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
