No network
ejirouti
My network totally disappeared from my phone since sunday. Today is tueday and the problem still remains.
How do I solve this?
8 REPLIES 8
@ejirouti , check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
edit, sorry, it shouldn't be blacklisted, since you tried the SIM into another phone..i missed. Good for you to test that though.
Still confirm below.
Also, log into your self serve account and ensure the 4 digits listed under the Change Sim Card feature under My Profile are the last 4 digits of your actual SIM card.
If the same - good!
If different, then someone has been fraudulent on your account let CSA know.
@ejirouti    You could try topping up your account with $1 and then rebooting your phone.  Otherwise it might be time to submit a ticket to customer support.  Here's couple of links, try the chatbot first though:
@ejirouti
Put it in lost stolen mode in self service and then take it off and reboot.
If still problems contact a CSA.
ejirouti
No service at all
ejirouti
Account status is active. I have re-installed the SIM multiple times, even on another phone.
Yummy
Do you mean you have No service at all or it is just data missing?
JK8
@ejirouti
Can you log into self service to see if your account is Active? Can you reset network settings or reinstall your SIM card?
