No network in Alaska
Crystal17
Travelling in Alaska now and there is no cellular network on my phone, even though my area is shown as included in the Public Mobile coverage map. I tried to manually register with AT&T but it failed. I'm currently on the $29/50G for Canada & US plan, and it worked without problem in Seattle and Boston.
Is there any way I can get cellular and data coverage? Any help is greatly appreciated!
7 REPLIES 7
HI @Crystal17
Alaska seems to be a tricky state for roaming.  Many had issue before, then connecting to AT&T works since late last year.  Maybe reboot the phone once more and try
Crystal17
Just tried now, unfortunately still not working and the same error message - "network registration failed. Selected network (AT&T 4G) unavailable". In the lower 48, my phone was able to automatically connect to T-Mobile, which is apparently not available in Alaska. I updated my post with screenshots of my network setting if that's helpful.
Crystal17
I turned on manual network selection, and "AT&T 4G" showed up. When I selected it, my phone shows "registering with AT&T 4G..." for a few mins, then with an error message saying "network registration failed. Selected network (AT&T 4G) unavailable".
HI @Crystal17
so, you try manual connection and don't see AT&T network there?
Crystal17
Thank you. But I have an older phone (Huawei P20) that doesn't support 5G. My network is set to 4G/3G/2G Auto and tried to connect to AT&T 4G, but it said "network unavailable". I have updated my post with screenshots.
fixin
@Crystal17 - Try going to LTE. There are certain limitations with AT&T.
Did you try restarting your phone? Were you on AT&T in Seattle or Boston? Or T-Mobile down there in the lower 48?
If nothing, try resetting your network settings *This will erase any saved Wi-Fi passwords*
HI @Crystal17
Make sure you don't choose 5G on the network mode, choose only 4G or LTE and then connect to AT&T only
(5G won't work and you won't be able to connect on T-Mobile in Alaska)
