No network after transfer
marwan
I transferred from Telus to PM this AM and still no network as of now. I answered YES to Telus to allow transfer. Then received text from PM saying I will receive my payment info and activation via email but still haven't yet. I checked the APN. Restarted phone many times. Not sure what to do.
17 REPLIES 17
marwan
I see, thank you! I've been in contact with CSA.
@marwan wrote:
What does no SIM provision mean? A message popped up one time and says exactly that. I got a ticket, waiting for a reply.
That generally means that there is no service assigned to that SIM card.
marwan
marwan
Under network icon, it says 'Emergency calls only." The phone does detect the SIM, there's a ring tone.
marwan
Yes I did power off, still no network. Thank you for your help!
marwan
I tested the SIM card into another phone. Still no network. I sent a message to CS agents and waiting for a reply. Thank you for the links, it helped!
@marwan So, basically calls and data both not working?  If thay is the case, it might be a SIM provision problem.
What is the phone message on top? No SIM? SIM not provisioned? No Network?
Open a ticket with PM and have them to confirm if SIM was provision properly:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
@marwan wrote:
It's active, just checked my account
Can you try a manual network search to see if Public Mobile shows up on the list?  Also does the phone recognize the presence of the SIM card?
@marwan
Did you reboot by holding down the power button and powering off?
Most people just turn off the screen but it needs to be powered off.
@marwan - can you test your SIM card into another compatible phone to see if services work?
If not, then contact Public Mobile Representatives customer support agents (CSA) to check on your activation/account, by either two methods, found here:https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
More troubleshooting found here for your model of phone:
https://www.helpsmartphone.com/en/android-blackberrykeyone-howtofixnoservice
marwan
Do you have self-serving account?
Does it say Active?
marwan
No voicemails, wasn't able to make any calls or text, just emergency calls only
marwan
Will try network reset.
Hi @marwan
Voice call working for both incoming and outgoing?  If yes and only data problem,  it is an APN setting.
Do you have and LG phone?  If yes, you will need to Refresh Network settings.  Let us know if it works
Update: see that you said you have Keyone, still try a network reset
marwan
BlackBerry keyone
will13am
@marwan , what model of phone do you have?  Some phones require a network reset in order to work.
