2 weeks ago
- last edited
2 weeks ago
computergeek541
Ibought this phone 4 months ago for my mom when I added the voicemail on it ,it stopped ringing.
i CALL HER IT RINGS 5 TIMES ON MY SIDE VOICEMAIL GOES ON
SHE CALLS ME LATER AND SAYS IT NEVER RINGS ON HER SIDE
DON'T KNOW WHAT TO DO ,IT HAS 1 YEAR WARRANTY .
NOT SURE IF I TRY TO GET RID OF THE VOICEMAIL NOT SURE HOW TO DO THIS
MAYBE IT MIGHT RING .SHE DOESN'T LIVE WITH ME SO IT'S HARD I NEED TO GO
ON THE WEEKEND TO TRY SEE IF I CAN DO ANYTHING.
DOES ANYONE KNOW ABOUT THIS PROBLEM?
2 weeks ago
You may have set the conditional call forwarding (or unconditional as well) options all to voicemail when you set up the voicemail. To reset all of the conditional call forwarding back to default enter ##004#. To reset unconditional call forwarding enter ##21#.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
2 weeks ago
In case there is a network issue, try setting the phone, at least temporarily, to 3g network mode.
2 weeks ago
@trixie2011 - oh, that is a tough one if you don't have the phone in your hands to see what is going on and the settings on it. Adding voicemail should not make calls go to voicemail.
Can she receive other calls ok, or are all calls going to voicemail?
So, my first question to your mom would be, does she have her do not disturb setting on? All calls would go to voicemail instead of ring.
If it is just select people that calls are going to her voicemail, see if she can go to the settings of your contacts app and check for the option for only receiving calls from your contact list. If this option is turn on, turn it off.
Or, ask her to add your number to your contact list.
2 weeks ago - last edited 2 weeks ago
@trixie2011 - also, sometimes turning off the phone (and not putting it to sleep..when the screen goes black), I mean holding down the power button until you see on the screen the option to Power Off. edit...and then turn it back on again. lol
fyi, i've 'tutored' parents remotely, I understand the challenges. If she has difficulty tech-wise, is there someone near her that could assist?
2 weeks ago
2 weeks ago
No she can not receive any calls thanks will try
2 weeks ago
she doesn't have data it's a flip phone she press buttons old style 80 years old mom
2 weeks ago
@darlicious wrote:You may have set the conditional call forwarding (or unconditional as well) options all to voicemail when
In case of forwarding:
- Phone WILL ring if forwarding is set up.
- Phone line will return busy signal if phone is off (or airplane set to on).
OP's wife's phone does NOT ring at all. Could be something with notification set up for phone app? Mute, disabled, ringtone issue, volume 0, etc.?
2 weeks ago
If it's blocked or any of the unconditional call forwards will send it to voicemail without ringing the phone first.
