09-10-2022 01:30 PM - last edited on 09-10-2022 02:55 PM by computergeek541
Hi, I have been trying so many times to login my account to reactive it. However, I am no longer able to login my account. Would you please advise whether it has been closed. My public mobile number is xxxxxxxxxxxx.
Thank you for your help in advance
Regards
xxxxxxxxxxxx
09-10-2022 06:09 PM
So it if was deactivated @dust2dust then OP should not have received a 611 text. Well, I guess if they are suspended they would not receive the text either. 🙂
@Siu porting your public mobile number from here to another provider also causes your account to close here, so you would no longer have access to your My Account any longer.
09-10-2022 02:43 PM
09-10-2022 01:39 PM
Please remove your phone number from public forum.
Try using different browser. Try Incognito mode. Clear browser’s cache. Try force refresh.
If nothing works and you still have service, contact agent to update your password.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
09-10-2022 01:34 PM
When did you last pay? I tried to get the status of that number and it didn't give me anything useful. Maybe it has deactivated. If you don't pay for 120 days then it fully deactivates.
