No incoming or outgoing calls
Lyn444
Just signed up with Public Mobile. Everything works except for phone calls
2 REPLIES 2
hi @Lyn444
try reboot phone first.  try also Reset Network Settings
if that does not work, try changing the network mode to 4G or LTE and see if it improves
if sane, ask PM to check the activation
please submit a ticket with CS Agent using  direct message
@Lyn444have you rebooted the device ? Try that first if still same you can ask for update from porting team will send you the number private message and they can re trigger the port request if needed
check you community in box for number
or you can use this link to the community in box
