07-22-2019 10:29 AM - edited 01-05-2022 06:01 AM
Hello
I have 1 gig data (500mb+500mb) , my phone and messaging work but my data doesn't seem to be connecting, I am thinking my sim card might need to be reset / changed , any ideas?
Thanks
Joining Public
07-23-2019 05:33 AM
It seemed APN was the issue , after setting the proper values and parameters the problem was solved .
Thank you all , you guys are great .
07-22-2019 10:43 AM
@Penholder wrote:Hello
Thanks
@Penholder If calls and texts work then there is nothing wrong with yout sim card so there is no need yo change it. If data is not working it's one of two things:
1. You used up your data allotment
2. Phone settings issue. Check apn.
07-22-2019 10:43 AM
If you are using LG phone, you need to do network reset after changing provider before you data working again. Restart phone after network reset to setup the APN.
07-22-2019 10:40 AM
Check your account to make sure it's not all used up. It should list it and what's left in the plans and add ons
07-22-2019 10:33 AM
Thanks
Did you turn on data? What phone you are using? You may need reset APN here:
https://apn-canada.gishan.net/en/apn/public-mobile
07-22-2019 10:31 AM - edited 07-22-2019 10:33 AM
Make sure you have the correct APN settings.
When you log into your self serve account - is an amount listed under data and add-ons ?
07-22-2019 10:31 AM
Thanks
What make/model/submodel phone is it?
If you've just signed up then
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
