4 weeks ago
Please investigate why there is no data in a few days as I have paid $25+tax for 10GB at 4G, thanks
3 weeks ago
@ Happy-12345
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
3 weeks ago
@ Celina1992
3 weeks ago
@ Dawse
3 weeks ago
@ LeonLee
3 weeks ago
@ Chen1485
4 weeks ago
Thank you - the Airplane Mode hack has worked for me for now!
4 weeks ago
Hey G!
Apparently, the issue has been resolved.
I would recommend placing your phone into airplane mode for one minute, then turn it off and reboot. This will help reconnect to the network. Worse case, do a network reset on your phone and reboot. As silly as it sounds, you may also want to log in and confirm your account is up to date.
If you're still having issues and these two options don't resolve it, contact customer service to advise the next move.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
4 weeks ago
So my phone does not seem to be able to use Data at all today, but I can't seem to find any evidence that would be able to suggest why.
My Public Mobile online registry says this:
1.91 / 24 GB used
Last Updated May 28, 2026
Now, my phone itself says this: Current Period 18.4 GB (which is still below 24 GB - also a shock to me because I don't think I've ever been above 2 GB before and I don't know what was different this month)
Additionally, I have two one-time add-ons of 2 GB each that are unused. The phone seems to work completely fine in every other way.
No tinkering I've done seems to be able to restore my data usage and connect me to the internet. What's going on?
Thanks!
-G
4 weeks ago
@sam361 wrote:is there a problem with the network ?
Hello @sam361
If you're having network issues, I usually suggest placing your phone into airplane mode for 1 minutes and then turning it off and rebooting.
Second is dialing 611 from your phone and confirming your account active. You can also log in online to confirm.
Network issues can be found here.
4 weeks ago
hi @sam361
Data problem with PM. PM has resolved the issue:
Start with Reboot phone and click Reset network settings
If same, please report your issue with PM support agent for help
submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
4 weeks ago
4 weeks ago
@Steve1621 wrote:Lost all
Since this is a community of all customers, instead of just directing you to customer service, let's see if we can problem solve.
Have you tried dialing 611 from your phone or log into your account online to see if your account is active? Sometimes, even if we have a credit card on file, sometimes there's a glitch and it misses the payment using said credit card.
If it is paid up and you're all solid there, try going into airplane mode for 1 minutes, then turn it off and reboot your phone. If that doesn't work, try a Network Reset. This will help your phone reconnect to the Public Mobile as well. If that doesn't work, try your SIM card (if that's an option) in a different phone and see if it works. Sometimes taking the SIM card out of the phone, rebooting it then re inserting the SIM card can help as well.
If none of these work, then you can reach a CS Agent to see what's gone off the rail sort of speak.
4 weeks ago
As of the most recent announcement update, the data issue has been resolved. This might be a totally different problem.
4 weeks ago
hi @Steve1621
please reboot your phone again.
if same, submit a ticket with CS Agent using Chatbot here:
4 weeks ago
Lost all
4 weeks ago
the issue was noted and PM deployed a fix this afternoon:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Resolved-Megathread-Public-Mobile-Data-Is...
Our technical teams have completed additional updates to resolve any residual issues that some customers were experiencing. Any remaining customers that were experiencing issues should once again follow the airplane mode steps listed above to restore services to their normal state. For anyone that is still experiencing issues with their services, please open a support ticket for further assistance.
Or your might also want to reboot your phone once again
if issue persists, please engage PM support for further investigation. Please open ticket with PM support:
4 weeks ago
Hello,
Does anyone have problem using PM data? This Tuesday (May 26), I tried using my phone's data because I was on a square where there is no public wifi service but I just couldn't get connected with Internet! Can PM staff explain what is going on? I don't want to pay almost 30 dollars per month for nothing! I usually don't use data much but I couldn't even have Internet access when I did need it! This is insane! I want a compensation for this!
Sally
4 weeks ago
Known issue. Supposedly now fixed.
Airplane mode on, then off. Then reboot phone.
4 weeks ago
4 weeks ago
4 weeks ago
Is there a problem with data today, may 28?
4 weeks ago
Without mobile Internet for days. Why is there no communication about what is going on?
Why are we paying for a service that is not working?
4 weeks ago
It seems like a lot of people are having the same issue...
4 weeks ago
Same issue here. Replied under this post and hope they can see the issue is still there: https://productioncommunity.publicmobile.ca/t5/Get-Support/Megathread-Public-Mobile-Data-Issues/td-p...
4 weeks ago
Hello,
I sent a message 3-4 hours ago but haven't heard back. My data is not working even though I have remaining data. Please help me resolve this ASAP. This problem has been ongoing for the past few days.
Thanks.
4 weeks ago
Thanks for the info and your suggestions. I have tried all the suggestions a few times but nothing. My daughter and I must be affected by the data outage. Thanks again
4 weeks ago
Are you having data issues then?
Known data outage affecting some customers the last few days. PM is working on a fix. ETA is still unknown. You can try rebooting your phone or toggle airplane mode on then off.
Here is additional information:
4 weeks ago
CS_Agent,
Yesterday I lost network service. I have data, but it doesn’t work (no internet connection). I can make calls, but recipients can barely hear me. I can send text messages, but they either take a long time to send or return an error.
I restarted my phone and followed your suggestions, but nothing helped.
4 weeks ago - last edited 4 weeks ago
hi @Alex_mc and @Jay199908
Data problem with PM. PM is working on the issue:
If same, please report your issue on the announcement link I provided above
4 weeks ago
I have the same issue in NS
