No calls coming through
Janettepomroy
Switched providers last night. I can receive texts and call out but I cannot receive calls
Timer
@Janettepomroy
If the previous troubleshooting steps didn’t work, and it has taken more than 2 hours to transfer your mobile number,  you will need the help of a Customer Support AgentChatbot
@Janettepomroy
If you didn’t port your old number over to PM and picked a new number, just reboot your phone by holding down the power button then turn off the phone. Reseat the SIM then power the phone back on.
Yummy
Did you do porting of your number at the same time you switched providers?
So can you receive calls or not? Your post is confusing.
@Janettepomroy
A critical part to porting is to receive a text from your old provider and reply YES within 90 mins.  Look  like you might have  missed the step and hence porting was not completed
There is a number to all to talk to live support and the can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get it fixed
dust2dust
Did you leave the old sim in and confirm the transfer within 90 minutes? Is your old service still working?
RossN
@Janettepomroy hi did you leave your old sim in your phone to receive transfer text,you have 90 minutes to reply yes I will send you the number to reinitiate port request
