02-16-2023
05:54 PM
02-18-2023
11:59 AM
Dunkman
I havent been able to call or receive phone call for 3 days. When people try to call me, they go straight to my voicemaill or when I call it seems that there are nos services.
I’ve verified airplane mode, do mot disturb and restart the phone. I have an IPhone X and I’ve used public mobile for more than 4 years. 2 years with the IPhone.
phone call work on the 3G but very badly.
02-16-2023 09:05 PM - edited 02-16-2023 09:07 PM
@felixsav3 - you've posted a couple days ago with same issue. Still no improvement? Can you confirm your My Account status is showing ACTIVE, or call 611 to check.
edit, here is your first post: https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-make-or-receive-phone-call/td-p/948...
At this point, I'd submit a ticket to CSA to see if there are issues in your area/towers and see what they say.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
02-16-2023 06:30 PM
Check here to see if there's an outage around your area: https://www.telus.com/en/outages
Also doesn't hurt to check here:
https://www.ertyu.org/steven_nikkel/cancellsites.html
To see if cell towers around you have changed (unlikely but you never know). Calls go through the 3G network, so try to locate 3G towers around your area.
02-16-2023 06:03 PM
Does texting work? both in and out?
How about your data?
If so, try these fixes:
